*help* Wondering if any one else has the same problems
Old Apr 28, 2006 | 10:06 AM
MBcrazed's Avatar
Hello, I am wondering if anyone else has a problem with the ML making noises on the underside (atleast that's where I think it is coming from).
Okay, I gas from a stopped position there's this loud clicking sound. It only does that when I gas. I was wondering if anyone knows anything about this. Apparently this 'problem' can't be fixed and it is 'just the way it is'.
Any help will be appreciated thanks!
Old Apr 28, 2006 | 12:23 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Had 2 W163's before my W164. What you described is not normal and not the way it should be. Perhaps your Cats are bad or there is a problem somewhere in the drivetrain. Never had this in either of my W163's.
Old Apr 28, 2006 | 05:08 PM
MBcrazed's Avatar
So during your ownership of the 163 you never had any problems in regards to the vehicle having "sounds" or "clicking" noises of any kind? How about the car shaking a little bit?
Old Apr 28, 2006 | 07:21 PM
sosh's Avatar
No such problems, in fact both my 98 and the 02 ML500 were very good. A few electronic glitches that my dealer took care of and on the 98 a few rattles but all taken care of with no recurrences. However my W164 ML500 is without question the best of the lot with no problems whatsoever. Its been flawless.
Old Apr 29, 2006 | 12:49 PM
justinwrock's Avatar
Ducati
The sound is a creaking/popping kind of noise. Mine does it when you are coming to a stop or accelerating. The problem in mine and still is that thw rubber boots that hold the sway bars, torsion bars, etc. are just drying out a bit. Mine got a nice coat of silicone spray to moisten em up a it, and they were fine for about 3 months.
I had them all replaced, and they were nice and quiet for about a year. The noises started to come back with time, and since then I have learned to live with it, and keep em all lubed.
Old Apr 29, 2006 | 12:54 PM
Reynaldo's Avatar
'03-ML350 'inspiration'
...Hhhmmm...Doesn't happened to mine.
Old Apr 29, 2006 | 03:17 PM
pointman's Avatar
a car that can't do the throttle reset.
torsion bars. fact.
Old Apr 30, 2006 | 06:52 PM
MBcrazed's Avatar
So the only way to fix this problem is to keep it lube?
Old Apr 30, 2006 | 07:08 PM
sosh's Avatar
Lubing is only a band aid. For a long term fix, replace.
Old May 1, 2006 | 12:48 PM
hanniep's Avatar
01 ML55, 91 Supra Turbo, 05 Audi S4
Sometime ago I experienced shaking from a hard launch and at that time it was suggested that I have the center axle bearing checked?????? Mine was OK, but you might want to have that checked too.
