Rough Downshift on 99 ML320
Old May 10, 2006 | 10:24 AM
Skibumtx's Avatar
G'day,
I've begun noticing that the transmission on my '99 ML320 (80K miles) has started to, dare I say, Clunk when it downshifts while coming to a stop. It doesn't happen all of the time but it seems to happen a couple times a day when driving around town. It also seems that the tranny "hangs on" to first gear a bit longer than I've come to expect during acceleration.
I recently (2 months ago) had the the car into a private shop to have some minor leaks repaired and they performed a transmission service including the changing of the fluids. It actually leaked worse for a couple days after the service and the shop looked at it and said they had overfilled the reservoir - apparently it's not real easy to measure the level. The leaking stopped but I'm wondering if these recent problems may be related.
Any thoughts?
Ski
Old May 10, 2006 | 10:55 AM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
They could have used the wrong fluid. Its very important to use only MB fluid or an approved alternate if there is one. The wrong fluid can cause permanent damage.
Old May 10, 2006 | 01:07 PM
Calcio's Avatar
1998 ML320; 2005 Audi A6; 2006 Honda Pilot
Get used to it
Originally Posted by Skibumtx
G'day,
Any thoughts?
Ski
Yep- they all do that or at least mine does and has for a loooong time.
Old May 10, 2006 | 01:43 PM
sosh's Avatar
Do not know how you can say that. Its not so. I had 2 W163's, a 98 and an 02. Neither of them had any trans shifting roughness or issues. You must have a problem also like the guy who started this thread.
Old May 11, 2006 | 10:01 AM
Skibumtx's Avatar
I checked with the shop and according to their records they used the MB ATF - so i don't think that is the issue.
I bought this car when it was new and this tranny clunk is definately more pronounced than it has been over the life of the vehicle.
Ski
Old May 11, 2006 | 12:30 PM
Calcio's Avatar
Common Problem
I've owned the 98 for 8 years and have been to several dealers in my area. The "tranny clunk" is a common issue and no one has ever been able to do anything about it. Perhaps, it is a matter of degree with it being more noticable to some than others based on driving conditions.
Old May 11, 2006 | 04:59 PM
pleubner's Avatar
W163 W164 R230
Overfilled the reservoir???? Didn't know there was a reservior for the transmission!
Attached Thumbnails Rough Downshift on 99 ML320-fluids.jpg   Rough Downshift on 99 ML320-transmission-fluid.jpg
Old May 11, 2006 | 05:01 PM
pleubner's Avatar
W163 W164 R230
Checking the Fluid Level
Checking the Fluid Level - Kim Langley
Attached Thumbnails Rough Downshift on 99 ML320-01.jpg   Rough Downshift on 99 ML320-02.jpg   Rough Downshift on 99 ML320-03.jpg   Rough Downshift on 99 ML320-04.jpg   Rough Downshift on 99 ML320-05.jpg
Old May 11, 2006 | 05:02 PM
pleubner's Avatar
W163 W164 R230
Checking Fluid - WIS
Attached Thumbnails Rough Downshift on 99 ML320-ainspect-fluid-level-01.jpg   Rough Downshift on 99 ML320-ainspect-fluid-level-02.jpg   Rough Downshift on 99 ML320-ainspect-fluid-level-03.jpg   Rough Downshift on 99 ML320-ainspect-fluid-level-04.jpg   Rough Downshift on 99 ML320-ainspect-fluid-level-05.jpg
Old May 11, 2006 | 05:08 PM
pleubner's Avatar
W163 W164 R230
Checking Fluid - WIS cont.
Attached Thumbnails Rough Downshift on 99 ML320-ainspect-fluid-level-06.jpg   Rough Downshift on 99 ML320-ainspect-fluid-level-07.jpg   Rough Downshift on 99 ML320-ainspect-fluid-level-08.jpg
