ML 320 with 113000 miles
Old May 11, 2006 | 12:05 AM
zeeyo987's Avatar
Hi. I have an 2000 ML 320 with about 113000 miles on it, and it runs strong no problem at all, the only thing i needed to change was the crank shaft position sensor and a part of the computer, and that was because the mechanic messed up the computer when trying to fix the crank shaft sensor. I have noticed that every once in a while the car jerks a little when changing gears, this has been going on for some time now, probably sinc eabout 80,000 miles or so. I had one mechanic look at it and he said that there was nothing wrong. Is there something i should be weary of right away?
thanks
-shan
Old May 11, 2006 | 07:53 AM
azinn's Avatar
2014 RX 350 F Sport, 2007 Scion tC, 2000 ML 430 Money Pit Finally Gone! Oh Happy Day!
thanks
-shan
If you haven't already changed the transmission fluid & filter, it probably should be done. My 2 cents.
Old May 11, 2006 | 08:21 AM
cyeung65's Avatar
Q & R
I have an 00 320 also, and I ran my last oil change over 9k miles per the VSS. I would get the valve lifters clacking on a cold start up. Its gone now with the new oil. Do you notice anything like that?
Old May 11, 2006 | 02:33 PM
zeeyo987's Avatar
00 ml 320
hmm i never really noticed that, illmake sure to change the fluids though. do u guys think that its probably time to change the tranny though?
Old May 11, 2006 | 03:41 PM
azinn's Avatar
Read this http://www.mercedesshop.com/shopforu...ission+service and you can decide.
Old May 18, 2006 | 03:26 PM
ml350's Avatar
2005 ML 350
does the 350 have the same trans as the 320. Or did mercedes put in a new trans on the 350 and 500.
Old May 18, 2006 | 03:52 PM
pleubner's Avatar
W163 W164 R230
My trans blew up .. and I had to replace it just a few weeks ago! So I know a little about it! Here is the manufacture roadmap.
(MY 1998 - 1999)
http://4x4abc.com/ML320/ML_specsII_old.html
(MY2000-2005)
http://4x4abc.com/ML320/ML_specsII.html
The full DIY (loads of pics), checking fluid levels, etc,etc.... are on the P3 forum!. I took a picture of every step of the transmission removal & install.
I also posted the WIS & EPC for all transmission related info!.
www.pointedthree.com
PS: Someone had a problem in the UK with his ML270CDI transmission after I did mine. After reading my posts he went out and bought a trans+converter+ transcase from a wrecked MY2004 ML, then hired a car lift and followed my DIY replacement single handed !.
Old May 18, 2006 | 04:01 PM
ml350's Avatar
2005 ML 350
these two sites has info on 320 only,
it does not have any info on 350
Old May 18, 2006 | 04:05 PM
pleubner's Avatar
W163 W164 R230
You mean 350 and 500 are missing right? .... because 230,320,430,ML55, 270CDI, 400CDI are listed!
The 500 has the same transmission as the ML55 and the 400CDI! Now to the 350 .... give me your VIN and I'll look it up! .... actually I posted all the Partno's on P3 of each model ....
.... ahhh silly me ... It's right at the beginning of my DIY .... You have a slightly different transmission than the ML500!.
NOTE: Since initially the 320 transmission was too weak (could not take the engine torque) , design changes were made, as well as pieces inside the transmission. Over the years as each transmission failure was analysed to the reason why it failed , modifications where made to improve it. .... So although the partno for a particular model might never change, the guts did! ....
In my case I have a 722.661 (ML270CDI). The new exchanged transmission has all the design changes incorporated. e.g parts that should not move and did breaking down now have holders, magnet in the pan, etc,etc....
Attached Thumbnails ML 320 with 113000 miles-transmission-types-models-my-.jpg
Old May 18, 2006 | 04:13 PM
ml350's Avatar
2005 ML 350
he the vin,
4JGAB57E55A545752
Old May 18, 2006 | 04:30 PM
pleubner's Avatar
W163 W164 R230
bump!.
Old May 18, 2006 | 04:48 PM
ml350's Avatar
2005 ML 350
so ml350 is on it own,
nobody else shares the same trans, with 350
Old May 18, 2006 | 04:52 PM
pleubner's Avatar
W163 W164 R230
Now that's a hard question what other MB's have the 722.674 Transmission ?
PS: Remember they vary ever so slightly! Mainly in the ECU (Electronic Control Unit)
Old May 22, 2006 | 02:58 PM
Pottie's Avatar
W163 & 203
Ouui..... I m right behind u buddy....
Mine is 2000 ML430 running a bit over 113K now....
I had recently tune it and and changed the brake oil...
Car running even smoother now since I moved to dallas....
