HID Retrofit Question...???
1 Post
2009 C350
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
There are some new bi-xenon headlamps for sale on ebay that are quite expensive, however I read in the auction that they require an adapter for them to work properly AND need to be programmed at the dealer...??? I thought my '03 is "plug and play" and only needs the xenon enabled at the dealer, but an adapter...??? ANY IDEAS??? thanks!
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Installing Bi-Xenon Headlights on 2003 MY ML
Essentially Plug and Play with a Minor Modification Published on Monday, November 24th, 2003 by AndyFracica
To make the Bi-Xenon headlight assembly work with the exisiting wiring harness on the ML you must connect the two grounds together. This modification essentially connects the two grounds on the Bi-Xenon connector together which allows you to use the stock ML connector to plug into the back of the headlight assembly.
http://www.benzworld.org/tech.html?id=176
'02 Bi-Xenon supplementary halogen high beam modification
Supplement your N.American Bi-Xenons with the H7 high beam flash-to-pass bulbs Published on Saturday, July 27th, 2002 by Drew
http://www.benzworld.org/tech.html?id=67
