sunroof adjustment???
Originally Posted by imwalkin
stil rattling!!!!!
With it fully closed (or as "closed" as it can get if it's having problems), pull down on the control switch (i.e. as if you were closing it from the up-tilted position) and hold it that way for about 20 seconds; eventually, it will raise itself to the up-tilted position.
Now, using the control switch as normal, close the roof, then slide it open fully (hold the switch - don't use its auto mode), then close it fully. This should re-sync it.
I copied the above process from another forum, I hope the contributor does not mind.
