Ml320 A/c Problem-need Help
Old Aug 17, 2006 | 02:35 PM
chris1964's Avatar
Hello.
I would like to know if anyone has encountered this similar problem with the airconditioning system of the ML320 ( 1998 ) when it is turned on :
When the center A/C dial is turned from low to high/maximum A/C airflow
( counterclockwise direction ) - to increase the flow of cold air into the passenger cabin - there is a loud " clacking " noise that is heard. Only when this dial is turned clockwise - to the low A/C air flow setting and is left running for about 10 mins or so - and then turned back to the high/maximum A/C airflow setting - does the noise disappear.
Can anyone tell me how to fix this annoying noise problem?
Thank you for any help
