Mysterious BAS/ETS/ABS lights don’t want to go away..
http://www.mercedesshop.com/shopforu...d.php?t=163247
Pictures:
http://www.mercedesshop.com/shopforu...d.php?t=163321
New to this forum and new to the W163 world. I am from Greece (far away e?) and I own a 2000 ML320 with 50,000 miles on. I had my car serviced in an authorized MB dealer (as always do) and after couple of weeks the ABS,ETS,EBS warning leds came on, and then off, and on... and so on.. The car is driveable however low range and cruise control will not work as long as these warnings are on. I have scheduled an appointment to the dealers but after reading all these I will think about it again.. So here comes the request that will also serve other newcomers with similar problems..
a) Can someone summarize the likely causes of this problem (including fuses codes, etc)
b) Can we have a picture of the fuse box and where is located?
Thank you very much for any help.
Seems like MB should have a recall on these pumps/problems as so many of us owners have reported the same issue...
After much diagnosis ,and looking on MBcircuit diagrams of the CAN network the fault was the trip computer above the mirror going down and pulling the CAN bus down so comms on the ABS ecu were first to go.Left the computer disconnected and everything now ok,lengthy diagnosis but a cheap fix, so try disconnecting that first!
Where exactly is that K25? I definitely need to have a look at it. Fingers x'ed it will solve my problem as well.
Cheers,
Gab
Why don't you try scanning the car for codes. Its good to read threads & have an idea, but each case is different. Getting the car scanned with a pro level scanner must be your first step to diagnosing your problem. Anytime you have the ESP light on means you will have stored codes in the ESP module & corresponding codes in others. Knowing these codes will be the answer to the issue, instead of guess work.
I don't think it will be of any use to you.... Relays are different even on different year & model ML's........
Why don't you open your fuse box & check the chart. What exactly K25 relay is in your car...Do you even have a K25 relay? Check on the chart ABS relay. After locating it, the part# will be on top of it.
The ESP systems are very different on a CLK & ML's.
Go to your own forum and find its location and see if it has a small fan inside the box.
Since getting it back, the BAS/ETS/ABS lights keep coming on (they never used to come on before – the brake switch has once been replaced a couple of years back to resolve a similar symptom).
This is what happens. In the morning at cold start they usually don’t come on for the 12 mile drive to work, but in the afternoon at lunch hour, start the truck and the lights will come on in less than 2 minutes of driving.
They will come on, on every start up for the rest of the day and the on the next day the same cycle repeats.
I already inspected the ABS relay in the fuse box, made sure the brake light bulbs are not blown, replaced the brake switch yesterday, as these are common causes of this problem. Everything seems fine. The brake lights even come on every time the brake paddle is depressed, but the mysterious lights don’t want to go off after lunch hour.
It almost seems like the afternoon temperature has something to do with the lights coming on. Only other anomaly I noticed is that as part of the B service, the brake fluid has been topped off a bit too much (way above the max. indicator)..is there something as topping off the fluid too much? Would that cause it?
anyway, as long as im driving alone, everything seems to b ok, but when ever i pick some one, to b precise, when ever tow persons come along, and after they get in and after i drive for lets say less than a min, the bas esp brake light turns on and starts to beeb constantly !!! Has it ever happened witb any of u ?!?!?
Plenty of discussions and solutions on this.
