My "check engine" went on..what does that mean?
Old Sep 9, 2002 | 05:17 PM
andaya's Avatar
99 ML 430
Angry My "check engine" went on..what does that mean?
I know this can mean anything, but I checked the manual and it states that it can be your gas cap tighten or your fuel filter has to be changed. I noticed this after filling up, so I didn't worry to much. The next day, it went away. wheew.
So, today I filled up the gas tank and again the "Check engine" when on. I'm like, what the hell?
So before I turn it in to the dealer,( and pay million dollars :P) has anyone have/had this problem in the past? and if so, what is the problem?
Andaya
Old Sep 9, 2002 | 08:00 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Gas cap is only one of the many items that will turn this on. Most of the items are emmissions related. Most likely its an O2 sensor that has failed. The dealer is about the only one that can read out the computer and detirmine exactly which component to change
Old Sep 9, 2002 | 10:49 PM
jco-amg's Avatar
ML 500 Sport
do you you turn your engine off when you fill up?
If you don't, you can generate that error message.
Old Sep 9, 2002 | 11:04 PM
andaya's Avatar
99 ML 430
Thumbs up Engine off while pumping gas
thanks though
andaya
