OBD-II High Flow Catalytic Converters
Old Nov 30, 2006 | 08:14 PM
df666's Avatar
2000 ML 320
Since my cats are cracked, I took my ML to the dealer to get them replaced and they refused to replace them because of the Magnaflow muffler I had installed a few months ago. I need to have them replaced myself and my dealer claims they will reimburse me.
I have seen some older posts that say that a high flow OBD-II compatible converter is not available which I believe was true at the time. I just found these:
http://www.rpmoutlet.com/powercat.htm
and I'm wondering if I should give them a try! Any help you guys could provide would be appreciated. Thanks!
Old Dec 3, 2006 | 11:14 PM
mbtech360's Avatar
You can buy a univeral fit cat and have it welded into the exhaust, theyre actually relatively inexpensive, but it involves more labor to make them fit.
you can find them at www.summitracing.com
Old Dec 4, 2006 | 04:24 AM
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
That a bunch of bull. Cats are warranty for 8 yr or 80k miles. I would ask again and ask in which document states that you cannot change the muffler and Doing so will void your Major emmission component warranty. If you press harder they may change it.
If you decide to not deal with the dealer then you can go to Valley Muffler in West Covina. (Valley and Nogalas) They can weld in a Magnaflow hi-flow cat for $120 each installed.
Old Dec 8, 2006 | 01:09 PM
df666's Avatar
2000 ML 320
Thanks fkong777!
Thanks for the replies guys! I am very familiar with Valley Muffler! I'll be sure to go to them! Thanks again!!!
