ML 230 driver electric seat not working?
Old Dec 3, 2006 | 06:29 AM
pyoung7453's Avatar
ML270 CDI Auto
Unhappy ML 230 driver electric seat not working?
Hi all,
Can you help? I have a ML 230CDI and the driver seat electrical adjustment is not working, passenger seat is OK. Have looked in the fuse box and cannot see a fuse or relay for this, any ideas?
Phil.
Old Dec 18, 2006 | 06:46 PM
buddypetty's Avatar
two fuses are better than one, i guess
phil,
i have a 99 ML320 and found that there are not only fuses in the main fuse box for the power seats, but an additional 30A fuse for each seat is also located under the plastic cover directly behind the fuse box next to the firewall (all were located under the hood on the left side).
hope this helps,
Buddy
Old Dec 20, 2006 | 11:55 AM
w163ml's Avatar
Check fuses then check underneath the seat to make sure the wiring harness is not unplugged.
Sometimes the power seat will pull the plugs on the wiring harness off if moved forward or backwards to the max.
