Dashboard lights
Old Dec 13, 2006 | 04:08 PM
pomko's Avatar
2025 E450
Dashboard lights
The lights behind my heater/AC controls are out.
How can I remove the front panel to replace them?
Or can they be fixed some other way?
Or could the problem be something other than bulbs?
01 ML430
Roman
Old Dec 22, 2006 | 07:13 PM
Stiggs's Avatar
2003 CLK55
The same thing happened on my ML430. The dealer just had to replace the bulb. I don't think they charged me too much.....but I can't remember now.
Old Dec 23, 2006 | 07:19 PM
pomko's Avatar
2025 E450
Stiggs
Thanks for yor reply.
Any idea how that panel can be removed?
Roman
Old Dec 23, 2006 | 07:30 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Believe the bulb is accessable if you just remove the Knob. Do not believe the panel needs to come off.
Old Dec 23, 2006 | 08:29 PM
ACW's Avatar
ACW
1999 ML430
Pull the middle knob straight out and you will see a small bulb. Pull it out and replace it. That one bulb lights all three dials.
Old Dec 23, 2006 | 10:49 PM
Stiggs's Avatar
2003 CLK55
Originally Posted by pomko
Stiggs
Roman
Probably what these guys said....I'm not one to take **** apart. I leave that up to the professionals. LOL
Old Dec 24, 2006 | 10:05 AM
pomko's Avatar
2025 E450
ACW, sosh, and Stiggs.
Thanks for your suggestions.
Sounds straight-forward. I'll give it a try.
Merry Christmas and Happy New Year
Old Dec 27, 2006 | 10:17 AM
worried1's Avatar
Dashboard light.
The bulb is so small how does one access it and remove it on my ML320.
Old Dec 27, 2006 | 12:21 PM
ACW's Avatar
ACW
1999 ML430
I think I remember using tweezers with some duct tape on the tips to grip the bulb.
Old Dec 27, 2006 | 06:20 PM
pomko's Avatar
2025 E450
I replaced it today.
I bought a small length of stiff clear vinyl tubing at Home Depot, with a diameter small enough to fit snugly over the end of the bulb in the dash. (it was the smallest diam. that they had - 1/8" (??). I pushed the tubing over the end of the old bulb, wiggled it a bit, and pulled it out.
Then I used the same tubing to stick the new bulb in. (without touching the glass - since this can accelerate burn out).
Done in 30 seconds! (and the dealer didn't charge me for the bulb).
Once again, thanks for your advice.
