stiff accelerator pedal
Old Sep 14, 2002 | 10:57 PM
Stiggs's Avatar
2003 CLK55
so far only 1 prob with my ML...the gas pedal is extremely stiff. I have to press really hard to get it going. Compared to my CLK the ML gas pedal is horrible. I've read on other forums that people have been stretching a spring and lubing up all the moving throtle parts. I made an appointment with my dealer in 2 weeks. What a coincidence...my dealer calls me up today and asks if everything is OK? I tell him about my appointment for the gas pedal.....he says its a safty feature.....what???? I say....saftey feature or not I need it fixed. I kept my appointment....and I"m not driving her home until the gas pedal feels normal!! I know from other forums I'm not the only one who hates this awful gas pedal feel!!! I will tell the mechanic to stretch whatever...or just replace the damn spring with one from a CLK!!!
Old Sep 15, 2002 | 02:24 AM
Kar don's Avatar
Mercedes-Benz
I agree mine is also very stiff. Try some lubricating spray or something, I will mention it at my next service visit.
Old Sep 15, 2002 | 09:42 PM
jswedberg's Avatar
C32 AMG
Hmmm. I've never noticed the gas pedal being stiff. It is about the same as our other cars.
Is this a "feature" of '99 models?
Old Sep 16, 2002 | 08:52 AM
ima55r2's Avatar
2018 Mclaren 720s, 2021 Aston Martin DBX
sticky pedal
I think oiling the throttle cable is done on the "B" service.
Old Sep 16, 2002 | 10:13 AM
Stiggs's Avatar
2003 CLK55
when I say the pedal feels "stiff" what I mean is that it takes alot of foot pressure to get the pedal moving towards the floor. In the CLK I just touch the pedal and I"m off moving...but the ML I have to press harder than I normally should. Its like the pedal is resisting my efforts to move it.....whereas a normal pedal should just go with the flow. Am I making sense?? Anyways they better fix it. Not just a lube job either...they have to replace a spring or something.
Old Sep 16, 2002 | 03:42 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Had a similar problem with my ML500. Accelerator was binding and stiff. Was difficult to start out smoothly or make a smooth speed change. Dealer replaced the cable and the stiffness and roughness went awway totally. This is the cable from the pedal mechanism to the black box on the engine side of the firewall.
Old Sep 17, 2002 | 10:47 AM
Darkmann's Avatar
ML
Mine is not stiff and you make a lot of sense. This is more than just a lube job (it's not the sticky situation usualy related to the throttle body). You have same problem that Sosh had. Have the cable replaced and you'll be a happier MLer.
Old Sep 17, 2002 | 01:15 PM
shoobie's Avatar
'00 ML430; '00 C230K; '01 CL500 (passed along...)
our 2000 ML430 has had a stiff/clunky pedal since day one, and even after service B. thought it was normal. will ask for repair at next visit (hopefully not too soon).
Old Jul 28, 2004 | 01:05 PM
JacksML350's Avatar
This problem still hasn't been fixed on the 2004 ML350. It must be a deliberate, albeit stupid decision by MB.
Old Jul 29, 2004 | 03:02 PM
ML God's Avatar
Have the dealer replace the throttle cable
Old Aug 3, 2004 | 07:17 PM
Stiggs's Avatar
2003 CLK55
Wow this is a blast from the past. Just stretch that spring. That's what I did back in 2002 and it has worked great ever since.
Old Aug 17, 2004 | 03:21 PM
JacksML350's Avatar
Tried the stretch spring idea. It didn't fix this particular problem.
I took my '04 ML350 in to the MB dealer with the sticky throttle complaint and they claim they took apart the gas pedal assembly and lubricated the parts and the throttle cable. That did absolutely nothing to fix the annoying throttle linkage.
I will now demand they replace the cable.
Old Aug 17, 2004 | 04:14 PM
MadDawg's Avatar
2002 Mercedes Benz ML320
ya, my m class feels spring loaded, but atleast i can keep a steady speed,
Old Aug 17, 2004 | 04:47 PM
benzboy's Avatar
SL500 E320 ML350
Stick with your demand for a new cable. That's the problem.
