Clutch problems on Manual 270CDI
The history of my clutch replacement is:
After 75k miles clutch started slipping
Mechanic replaced it and the master cylinder (and milled the fly wheel to make it planar - it had warped a little). The clutch pedal had no play and it was heavy to press.
After about a month / 1k miles, I noticed it slipping again, and my mechanic replaced it again. The clutch has worn down.
After another 1 k miles it started to slip again. There is no fluid in the clutch, the slippage appears to be due to excessive clutch wear.
The slip seems to happen after things warm up, e.g. when on long journies
There are not many ML's with manual gearboxes around so I would not expect too many experienced replies to this post (yes, I know you only need one experienced reply and I'm sorry this is not it).
Problem solved. When the new clutch went it, I had to change the slave cylinder with it. But Mercedes have changed the size of the slave cylinder. As the size has changed you have to change the master cylinder also. The master and slave have to be matched or else when you press the clutch pedal the amount of movement in the master cylinder, will not result in the correspondingly correct movement in the slave cylinder. Solution is change the Master Cylinder also.
