Just found mystery rattle in rear
Old Feb 12, 2007 | 04:52 AM
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
I just fixed a rattle located in what appear to be in the rear of the ML. Source of the rattle is actually in the headliner. Yes the Headliner! Above the rear passenger headrest. If you push up against the headliner you may hear some loose tapping sound.
I dropped the headliner slightly from the rear passenger door area. You have to remove the coat hook, handle and this 2 door cover from rear passenger area and the cargo area. also pop out the B and C pillar cover and door seal from rear passenger area.
Upon dropping the headliner slightly, I found a piece of Plastic cross-member that is totally liberated from the headliner. So it is just sitting loose between the headliner and roof panel causing a lot of tapping rattle. Since it is just sitting loose in there and it is plastic I just remove it. I found all the glue in the cross-member to be hard and the cross-member just broke loose from the headliner. I believe the cross-member would help supported the headliner from bowing down. Well since it broke itself away. it is useless now. No way to glue it back on without dropping the entire headliner at lease from One side.
Wow what a difference without that annoying tapping rattle. It was driving me nuts.
Check on it if you have rattle in the rear that you cant find.
Old Feb 12, 2007 | 12:53 PM
gocargo's Avatar
Steel Grey 2012 ML350 is wife's
Thanks for the heads up.
-Bret
Old Feb 13, 2007 | 09:49 AM
marcelc's Avatar
2002 ML270
This was a timely post, it encouraged me to look at my headliner rattle, I found that the factory had been too parsimonious with the velcro (less than a square inch of it) so I put more on (above the rear seat backs) and hopefully it's better now.
Thanks.
