Poor fuel economy in 01 ML 320
Old May 13, 2007 | 11:13 AM
bbearden's Avatar
'03 E55 (My Daily), '01 ML 320 (Wifey), Twin Turbo '69 Camaro (In Progess)
My 01 ML 320 is getting roughly 10-11 MPG right now and I have a new air filter, fresh oil, and I even cleaned the MAF. Tire pressure is good as well. I have no error codes and the CEL is off so I am guessing an O2 sensor or the MAF is going bad. Accelerations seems more sluggish than previously which seems to be an indicator the MAF could be bad. Anybody else had symptoms like this?
Old May 15, 2007 | 09:58 AM
mihir_d's Avatar
2000 ML320 2006 SLK 350
It is very likely the spark plugs...
How many miles on your ML? It greater than 70K...its time for new plugs..
My mileage had dropped to 12 mpg too...the day I changed my spark plugs....it went back up to 17-18 mpg....
Old May 15, 2007 | 10:12 AM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Could be as posted above and/or the MAF may be marginal (They are consumables and not designed to be cleaned) or even perhaps an O2 sensor or all of them. Best bet is to get the readings for all of this stuff via a dealer's Star system and see what the actual values are. If marginal replace the components.
