ML320 sudden stop
Old Sep 5, 2007 | 08:41 PM
scart_mb's Avatar
ml320, 2001
Question ML320 sudden stop
On 9/5/2007, I tried to change the freeways from I-110N to I5N. My ML320 made a low noise and stop.
I turned the key several times. However, most lights were blinking and nothing happened.
Luckily, I could move to the open spot that was provided for the disabled vehicle like mine.
After 10 minutes have passed, I turned the key again.
Although I see "Check Engine" sign, I could go to the destination and come back.
Did anyone have this type of experience? Can anyone pin-point the problem?
After I read your stories, my problem may be due to CPS (Crank Position Sensor) or MAF(Mass Airflow Filter). But where is CPS? Anyone knows?
Thank you.
Old Sep 6, 2007 | 03:01 PM
azinn's Avatar
2014 RX 350 F Sport, 2007 Scion tC, 2000 ML 430 Money Pit Finally Gone! Oh Happy Day!
Thank you.
Sounds like a failing CPS to me, common problem that leaves no codes. See http://www.mercedesshop.com/shopforu...hlight=cps+diy
Old Sep 7, 2007 | 02:53 AM
scart_mb's Avatar
ml320, 2001
Smile Thank you.
Thank you.
