Brakes for 2000 ML 430
Old Dec 5, 2007 | 12:13 PM
khaiser's Avatar
Hi
My brake light on the dash keeps flashing on/off. Does that mean it is time to replace the brake pads? what about the rotors?
Nafees
Old Dec 5, 2007 | 02:24 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Rotors have a minimum thickness and must be measured with a micrometer to determine if they need replacement. They should also be replaced if grooved or warped. They should not be turned or cut.
Old Dec 6, 2007 | 07:15 PM
khaiser's Avatar
What brand brake and rotors would you reccomed?
Old Dec 12, 2007 | 08:50 PM
tomcat7's Avatar
2011 E550 4 Matic, 2000 ML430
Do you know what the specs are for the rotors? Normal Thickness, and minimum? Also what torque when remounting the tires?
Thanks,
Old Dec 12, 2007 | 08:56 PM
sosh's Avatar
Thanks,
I believe that the min thickness is stamped on each rotor. Can't answer the torque question.
Old Dec 13, 2007 | 05:09 PM
roberthelfrick's Avatar
2000 ml320 1986 560sel 1973 280se4.5
Torque should be 110 ft-lbs on the lug bolts.
Old Dec 27, 2007 | 10:26 AM
bensitto's Avatar
S550, R350, GL550, ML63 AMG
I replaced my stock rotors on my ML320 with Brembo rotors and Porterfield R4S brake pads. They are an excellent combo. If you get porterfields you need to break them in properly.
Rotors from:
http://www.thebenzbin.com/parts/?N=0...294967266+9179
Pads from:
www.formymercedes.com
