Sprint booster on an ML
Old Dec 27, 2007 | 12:48 PM
RAFFIE55's Avatar
Used to drive E55
Does anybody have a Sprint Booster on there ML430? I have one on my E55 and want to put one on my wifes ML430. Where is it located? Anybody have input as to if they like it or not?
Old Dec 27, 2007 | 09:13 PM
Chemaly's Avatar
2002 ML500 Sport
Sprint Booster
I have an 02 Ml500 and bought a sprint booster off of ebay for it.
I followed all the directions for the installation but unfortunately it will not work on the ML's (W163). There is nowhere to connect it like all other models.
If I am wrong please correct me anyone.
Old Dec 27, 2007 | 09:50 PM
Clk&Slk's Avatar
06' Clk 500 Cabriolet, 01' CL 55, 00' Clk 430
I'm 99.9% sure that it can be install. Most post-2000 model have the wire-drive-by throttle which the sprint booster installed into the gas paddle. But on the pre-2000 model, you need to find the throttle linkeage in the engine bay and follow it until the end. At the end of the throttle linkeage cable, there should be a connector that you can plug in your sprint booster. I know people that installed it on a 1998 Slk 230, 2000 SL 500...etc. Here's a couple example picture of a 2000 SL 500 with sprint booster installed.
Attached Thumbnails Sprint booster on an ML-sprint-20booster-20intall-20location-20001.jpg   Sprint booster on an ML-sprint-20booster-20intall-20location-20002.jpg   Sprint booster on an ML-sprint-20booster-20intall-20location-20003.jpg
Old Dec 29, 2007 | 10:12 AM
Chemaly's Avatar
2002 ML500 Sport
Thanks for the info
Has anyone else installed a Sprint Booster on a 02 ML500 ?
I want to try and install it tomorrow and any tips would be helpfull
Old Dec 29, 2007 | 10:18 AM
tomcat7's Avatar
2011 E550 4 Matic, 2000 ML430
What exactly is a sprint booster?
Thanks, I'd like to learn more about the performance improvement expected. I have a 2000 ML430 and love to get a little more out of it.
Old Dec 29, 2007 | 10:52 AM
Chemaly's Avatar
2002 ML500 Sport
Its a small chip
I found this info below on ebay from a seller
The Sprint Booster might very well be the "smartest" gadget on your car. It is a device that improves acceleration by continuously measuring and converting the digital signal provided by the ECT's potentiometer, and providing the ECM with a new and altered signal.
The design of the Sprint Booster allows for its easy installation in all models, without the need to cut any wires or intervene in the automobile's electronics (it does not affect other systems such as electronic injection, ABS, etc.).
Its installation is extremely easy, requires no specific skills or tools – apart from a screwdriver – and takes only one minute. With the screwdriver in hand, you simply undo the safety connector clip and plug-in the device in the throttle's connector. The other end is plugged-in at the clamp that leads to the ECM. The device is "idiot proof" as one end is a male connector and the other female.
It can either be installed by you – using the easy step-by-step instructions below – or at any authorized dealer.
Old Jan 2, 2008 | 03:35 PM
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
If you already have one. Try removing the one from your E55 and install it on the ML430 for Testing?
Old Jan 2, 2008 | 05:25 PM
RAFFIE55's Avatar
Used to drive E55
I have the AMG version. I need a non-AMG for the ML430. I am not sure what the difference is?
Old Jan 4, 2008 | 10:35 AM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
how much the throttle changes... its not as much of a kick with the AMG version because AMGs have considerably more power
Old Jan 7, 2008 | 09:58 AM
Chemaly's Avatar
2002 ML500 Sport
I installed a sprint booster on my 2002 ml500 and the engine would not rev up at all. when I put the car in drive it would only idle no matter how much I pressed on the gas pedal. I tried it sevral time
Does anyone know why this would happen?
Old Jan 16, 2008 | 10:21 PM
nanrye's Avatar
'04 Black C32; '00 Black ML320
Any updates on this? Thanks.
Old Jan 18, 2008 | 09:53 AM
dewdaltz's Avatar
02ML320/06R350
here is the update.
http://www.benzworld.org/forums/w163...=sprintbooster
Old Jan 28, 2008 | 04:21 PM
ctC230K's Avatar
excites your girlfriend
you either got a defective one and should return it or you failed to install it properly. are the connections as tight as they can be? plugged in all the way?
Old Jan 30, 2008 | 07:34 AM
stallion8797's Avatar
I got one for my C class and absolutley love it. I found for 260.00 through www.tvtdesign.com. Best price I've seen so far.
Old Jan 30, 2008 | 01:27 PM
Clk&Slk's Avatar
I have a non-AMG version for sale for $250 shipped. Drop me an e-mail at ldnguyen1971@hotmail.com if interested.
