Did you know that…
A few days ago I had a situation on the parking lot. I’ve inserted the ignition key, turned it to the starting position (position 3) and accidentally pressed the panic button. When I did this, the electricity in the car completely disappeared… No lights, no locks were working. Nothing.
I tried everything to start the engine but without success. I’ve checked the fuses and they were all fine. Finally, I’ve disconnected the battery and after a few minutes connected it again. After this everything worked again and I was able to go home.
I don’t know whether some of you had situation like this… Nothing about problem like that is described in the manual (or at least I didn't find it). I hope this info will help someone in a situation like I had.
well it may have been the lock out for the remot is to the fact car alarm, and it has a starter kill in it. if this happens a ginn try just to unlock and lock the doors . that seems to be a way of reseting the sys in the car. I had somthing like what you are saying and that seems to work
