ML 20" rim questions
New to the ML forums, but I'm helping a friend post about questions for 20" for his ML.
What is the typical setup or ideal setup for 20" rims?
Offset?
Size Tire?
Rim Size? eg. 20x??
Thanks in advance!
Rob.
Offset?
Size Tire?
Rim Size? eg. 20x??
Thanks in advance!
Rob.
I have 20" Brabus Monoblock IV on. The rim size is 20x9.5J w/ offset of 40. I have Yokohama AVS 295-45/WR20, although I think 295-40/20 would work as well. As a matter of fact, if you go with Dunlap SP9000 you'd have to go with the 295/40.
2008 C300, 2005 Odyssey Touring
I have 20x10's on my truck.
I have 20x10 Lowenhart BS-5's offset 35 with 275/40/20 tires. The overall diameter is just slightly smaller than stock so the odometer will not be way off. Also, you will find better deals on the 275 than on the 295.
