Door Panel Removal
Old Mar 21, 2008 | 04:19 PM
jefferino's Avatar
2000 ML55 (parted out), 92 1jz SC300, 92 Sentra (DD), 05 Cadillac SRX
Door Panel Removal
Okay so I have searched and what I have found is to take off the plastic trim around the door handle. Did that and supposed to be screws there...didn't see any. Next I started to try to pull off the clips around the bottom. That worked but it seems to be stuck all around the airbag and handle. Anyone know how to do this? I have to get it off to replace a regulator and a door lock actuator.
Thanks!!!
Old Mar 21, 2008 | 05:43 PM
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
There is a screw behind the "SRS" Logo cap. Couple more in the door handle.
Old Mar 21, 2008 | 07:33 PM
jefferino's Avatar
Thanks I will check under there and see if that is where the thing is being held on by. I took off the door handle plastic/wood and didn't see any screws underneath. Could the person who owned it before have taken them out and left them out? I am just trying to be sure that I don't damage anything.
Thanks for the help
