ML320: Code: P2050 / P2051: HELP !!!!
Old Mar 25, 2008 | 06:06 PM
AUTOQUESTION's Avatar
Mercedes Benz
I have a 2003 ML320.
The check engine light keeps going on and off and car starts shaking.
The scanner gave the following codes:
P2050: Misfiring Damages TWC P0300
P2051 : Misfiring cylinder 1 damages to TWC.
Sometimes it gives misfiring to cylinder 1, then 4 then 6 and so on.
One mechanic said the ECU unit needs to be replaced as the injectors dont get power.
The other TWO mexchanics said to chnage the spark plugs and ignition wires, which we did, but same problem.
WHAT COULD IT BE..?? PLEASE HELP !!
Old Mar 26, 2008 | 03:21 PM
davethebenzman's Avatar
1988 300E, 1973 450 sl, 1999 ML320, 1986 300E, 1985 190D
Wow
P2050 Reductant Injector Circuit/Open
P2051 Reductant Injector Circuit Low
it sound like that the truck needs to get the injectors cleand
Old Apr 25, 2008 | 06:24 PM
angeleye328i's Avatar
or replace BTW is cheaper (IMO)
