ML350 HID Upgrade
Old Feb 24, 2008 | 08:21 PM
pDuBz's Avatar
2003 ML350
ML350 HID Upgrade
I have a 2003 ML350 with projector headlights.. I want to install an HID kit for the lights because i want the lights to be brighter.. and the info i need is the Bulb Size.. and if someone could recommend a kit then i can get things going.. Thanks.
Old Feb 25, 2008 | 12:26 PM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
H7 bulb size... you should use the search function, there is a lot on retrofitting HIDs already
Old Feb 25, 2008 | 03:42 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
yeah... STFF and u'll find plenty info...
btw, i'm running hid H7 and hid fogs on mine without any problems...
Old Mar 5, 2008 | 08:43 PM
RW C55's Avatar
'10 E63 Obsidiant Black; '06 R350 Alabaster White; 05 C55 Obsidiant Black (sold)
hey MJ50
Can you tell more about ur HID fog? I recently have an idea of replacing a set of HID fog on my OEM fog, yet i know nothign about wiring. Could you tell me where you got ur set and the size of the bulb? Thanks a lot
Old Mar 5, 2008 | 11:59 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
Originally Posted by RW C55
hey MJ50
on W163, fog bulb size is H8.
on ur C55, fog bulb size is 9006.
i got HID kits from k1 motorsport.
Old Mar 6, 2008 | 12:17 AM
Darkmann's Avatar
ML
There's only one bulb size that'll fit unless you plan to replace the entire lens. What you have to decide is what temperature range you want to live with. Anything above 6000K is strictly to have that bluish/pinkish look,..., all show!!! There's also possible a light scatter issue you'll have to deal with. I have never compared the lenses on HIDs vs Halogens, but I bet the design (those horizontal and vertical lines on the glass) is not the same. With a HID in a non HID lens, it may look cool but the light scatter may not be that great. I wish someone who has installed these after market units on an ML would respond. But the again, they'd never know what the OEM BiX's look like!!! I have done one of these retrofits on another vehicle. The night view is definitely better than OEM halogen projectors, but light quality from the driver's point of view is a whole other story!!!
Old Apr 7, 2008 | 01:49 AM
d-knows's Avatar
ML350 & C230
ML350 HID Kit
MJ50,
I recently purchased the K1 Motorsport H7 HID kit for my 2005 ML350. Got them installed with some modifications to the bulb retainer piece. By the way, did you have to modify the bulb retainer piece as well? More importantly, my HID's won't light up if they're switched on after the engine is running. I have to turn on the lights first and then start the engine. Did you have the same or similar problem?
Old Apr 7, 2008 | 01:07 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
i really don't know since i didn't do the install...
but i think the installer did modify the bulbs a little bit to fit...
no problems in terms of the functioning the HID kit...
Old Apr 25, 2008 | 06:15 PM
angeleye328i's Avatar
Just install my HID kit and it looks awsome!!! Way better then my stock. No modification or anything.. Simple plug and play
Old Apr 25, 2008 | 06:51 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
nice~
post pics!
