ML320 Starting problem
Old Apr 8, 2008 | 12:51 PM
jessiesm1's Avatar
ML320
I have a 98 ML320 - it will crank and run for 1 second and then die. It will keep on doing this. I used the 5 second test(turn key to on position for 5 seconds and then turn key) to eliminate any key issues - the key works(my older 2 keys will not pass this test). I pulled 2 codes - p0110 and p0204. I've read a lot about cps sensor, maf, fuel pump. Wanted to know which way to go first. Any ideas?!?
Old Apr 25, 2008 | 06:20 PM
angeleye328i's Avatar
Means you're not getting fuel (spark). Check your spark plugs and ignition coils. Then check your fuel pump. But I do recommend you try to find the code error before throwing money at parts you don't need replacing...
