Computer Range
Old Dec 3, 2002 | 10:04 PM
yobusdis's Avatar
ML500
Computer Range
Whenever my gas light comes on, the compass computer won't tell me how much further I can go with the gas I have, it just says "FUEL"... is there a way to change that so it reads out how far I can go even when im running out of gas?
Old Dec 4, 2002 | 07:57 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
When the computer is set to USA your's is behaving normally. There is no way to change it. A BMW I had did the same thing. If you change the computer setting to GER you will find all info in metric with kilometers and then the computer will count down to ) in kilometers. Its easier to just stop at a station and fill up.
Old Dec 4, 2002 | 08:03 PM
yobusdis's Avatar
ML500
Thanks, I know the thing is really accurate, i remember what it says right before it switches to FUEL and add it to my odometer... and when i fill up, it pretty much perfect, which is amazing for the way i drive. I wanted to see it in miles, but ill try out the GER setting when im low on gas.
Old Dec 9, 2002 | 04:17 PM
JJunkins's Avatar
2000 ML 320
Trippin Computer
Right before is switchs over to read "FUEL" is will read "60" miles remaining. I think that is the lowest it will go.
Old Dec 10, 2002 | 01:50 AM
GreenM3's Avatar
1999 ML430
I've seen mine read as low as 45 miles, but usually it goes to FUEL after 60.
My BMW's would go down as low as 10 before they start blinking...
as if to say, "You're on your own now, buddy."
Old Dec 10, 2002 | 10:29 PM
yobusdis's Avatar
ML500
Ive never seen it say fuel with out the gas light on or vise versa, is that accurate?
Old Dec 11, 2002 | 08:04 AM
JJunkins's Avatar
2000 ML 320
Yes, that is accurate.
