Does your volume get lower?
Old Dec 6, 2002 | 03:04 AM
rix713's Avatar
Angry Does your volume get lower?
does any have this problem.
When your drive and listening to you radio/cd. All of a sudden the volume gets lower. No one touched the volume knobs or anything...
I know some car stero deck has ASL (auto-senitive leveling). In which when the car's engine gets louder, the volume in turn goes up. Does the ML have this function or do i need to visit MB's service?
Old Dec 6, 2002 | 02:33 PM
missthebus's Avatar
02ML320
Audio Pilot
is what it's called
There are two functions that the dealer can enable or disable.
1. Speed compensation; volume goes up as speed goes up.( it's really annoying).
2. Noise compensation; automatically compensate volume depend on cabin noise level. (This is the technoloy marvel from Bose, it's suppose to be so good that the listener should not be able to tell when it's adjusting the volume). it share the same noise sensor on the overhead as the alarm system.
Hope this help
Missthebus
Old Dec 7, 2002 | 03:39 PM
rix713's Avatar
wow
wow.. thanks.. is there a way i can adjust it myself.. or do i have to bring it to the dealer?
Old Dec 8, 2002 | 10:11 AM
slcvr6's Avatar
Awaiting a new arrival...
I am having this same problem in my ML. We had the MCS unit replaced under warranty, but the problem persists. Essentially, while holding a constant speed, the volume on ours has increased as much as 10db and then goes back down to where it was previously. Occasionally, while holding a constant speed, it goes way soft. It is quite annoying.
Old Dec 9, 2002 | 09:23 AM
yobusdis's Avatar
ML500
I'm getting something like that too, but I installed an aftermarket subwoofer, and at random times(usually when i slow down considerably), the volume will spike to pretty much double what it was before. Does the frequency of the subwoofer match some frequency the audio pilot detects to control volume. Is this solvable by turning it off, or does this sound more like a Head Unit problem. The wiring and grounding on the subwoofer is sound. I'm just glad there is a speech function so i can cut out all the bass to make it go back to normal
Old Dec 9, 2002 | 09:54 AM
JJunkins's Avatar
2000 ML 320
Volume
My volume would just go wide open for no reason and not come down unless I turn it down. I hate it when it happens. Scares the heck outta me! I'll be driving just listening at a normal volume then BAM---AAAAAHHHHH!!! Crazy!!
Old Dec 9, 2002 | 12:59 PM
chris's Avatar
2000 ML430
Same with my unit, it randomly starts increasing.
It doesn't matter whether or not I'm accelerating or decelerating. All of a sudden the volume will jump and I have to lower the volume. I just got my whole MCS/NAV system replaced under warranty, let's see what happens with this unit.
Old Dec 9, 2002 | 04:40 PM
yobusdis's Avatar
ML500
It was replaced under warranty right. Does anything aftermarket void warranty??
Old Dec 9, 2002 | 09:47 PM
rix713's Avatar
thanks for all your replies
I thought this problem only happends to me. So, should i ask MB to check my radio/Nav system out?
Old Dec 9, 2002 | 09:48 PM
rix713's Avatar
SUBs??
i have the third row seats on my ML.. Where would i but the AMP and Subs if i wanted to install those?? Any pictures. I don't want to give up the roominess of my ML.
Old Dec 10, 2002 | 11:58 AM
chris's Avatar
2000 ML430
Yes, they replaced the whole thing under warranty
I have my amp under my rear seats (not third row) and the subs are occupying about half of the trunk.
Old Dec 10, 2002 | 01:29 PM
rix713's Avatar
where to place subs
is there any where else to place subs?? I don't want to give up my third row seats. Does the ML have any hide away subs?
Old Dec 10, 2002 | 01:34 PM
JJunkins's Avatar
2000 ML 320
I would suggest getting a custom box made at Hi-Fi Buys.
JL does not make a stealth box for the ML, not to my knowledge anyway.
Old Dec 14, 2002 | 05:38 PM
yobusdis's Avatar
ML500
Is there a technichal bulletin out on this problem... and what has to be done to get it fixed??
Thanks all.
Old Dec 16, 2002 | 11:05 PM
Stiggs's Avatar
2003 CLK55
Any pics of this stealth sub box???
I have a Clarion amp under the rear seats. (second row, not third row) The amp fits perfect....but where do I put a subwoofer??
