CD changer needed
Old May 28, 2008 | 04:16 PM
marc51's Avatar
Merc ML 270CDI
CD changer needed
Hi, i have a 2004 mercedes ml 270 cdi. I have an audio 190 head unit and am looking for a cd boot changer to fit. Does anyone have any suggestions where i could get one from? Thanks
Marc
Old May 28, 2008 | 07:37 PM
Solidjake's Avatar
02 330i & 99 ML430
i have one from a '99 ml430, but idk if it will work. if it does pm me a price and we'll see
Old May 29, 2008 | 12:49 PM
marc51's Avatar
Merc ML 270CDI
how will i know if it will fit?
Old May 30, 2008 | 09:41 AM
Solidjake's Avatar
02 330i & 99 ML430
i have no clue. maybe someone else can answer that
Old Jun 3, 2008 | 04:25 PM
moeck964's Avatar
ML55, 993, C230, Honda Insight, HD FXDL
You need to pull your audio unit to determine if the Fibre Optic (FO) cable is behind the unit. As you have a 2004, the mcs units utilized FO for the rear CD. Not sure about your basic unit, it may or may not have the FO cable but depends on your head unit, so best to pull and check. All US units had the FO. If the cable is there then it exists in the rear, a little difficult to find but it's there. One cable is tapped to harness, the FB cable is usually buried down low behind the plasitc panel. May have to loosen to find. If you have the FO, then I do have a CD unit that will work. FO's are in 2001-2005's
