ML is dead.. bad battery or something else?
I called the 24 hour service centre and they said mostly its the battery. He asked me to put the key to on position and see if the horn worked, it didnt. When I turn the key to on position tho, i noticed the ambient orange LED under the mirror lit up, and the green LED for the auto dimming lit up too. On the instrument panel, i saw some warning lights flickering but very dim..
They asked me to disconnect the car and try charging the battery. The thing is i dont have battery charger handy at home so I would have to wait till tomorrow to get a battery charger.
I'm just a little concerned as the last time the battery died on me, its just refused to start, the interior lights are still functional.
The battery just got replaced about 2 years ago, it was a battery made by Johnson Control company. OEM Mercedes battery is very expensive over here, dealer quoted $600 for it.
I'm just asking to see if anyone ever experience the same thing.. and if its normal that the car is totally dead when the battery is dead..
TIA guys
n fact, I am charging a Interstafe battery on my Porsche as I write! I even used a 1amp trickle charger on it when I put the car into storate 9 months ago - just put it back on the road today.
Just a quick tip on your ML battery - check for corrosion, loose battery terminals, and check the water level - you will be surprised how low it can get in the ML. I checked the water level in my ML a few months ago when the battery was not charging properly and it was probably down 40%! Top it off with distilled water before you charge it. And watch for gases while charging - I`ve had batteries explode during charge cycles.
search the posts or google for the right way to charge é jump start your car.
BTW, ask your service dealer if you can reconnect the battery safely without damaging the ECU etc in the car as you don`t want a voltage spike to fry that costly electronic brain!
good luck
The non OEM Battery im using now is maintenance free battery, and no corrosion present when I look at the terminals. The battery is 2 year old, so maybe thats the culprit.
Most of battery stores are closed on sunday, so I'm gonna have to wait till monday. Dealer's part dept is also closed on sundays (we only have 1 Merc dealer in town). I called the 24 hour customer service this morning and they suggested to buy non OEM battery somewhere else as they are selling them at higher price. Non OEM is about $170 for regular battery, $200-250 for maintenance-free batteries. OEM Mercedes battery is sold at dealer at $600
Dealer said they will come to my house and install the battery for me on monday, so I guess they'll know the safe way to reconnect the battery.
Thanks for the tips! I'll keep that in mind for my next battery. Maybe i should buy battery conditioner or something... as I rarely drive my car (2-3 times a week)
Anyone has any suggestion regarding battery conditioner/trickle charger for this car? Do I have to disconect the battery first to use that?
TIA guys
Thanks for the info
