WINDOWS CLOSES WITH AN 1 INCH GAP
Old Sep 27, 2008 | 04:20 PM
jtse's Avatar
my driver window on my 2000 ML320 comes up but leaves a gap of about 1 inch, is it out of sync, or what? I can still drive it, but the gap leaves wind blowing in all the time. The center console seems to be working since it is coming up and i can hear the motor clicking when it reaches the "top", but its about 1 inch away from closing completely, Any suggestions? Thanks
Old Oct 7, 2008 | 06:22 PM
jtse's Avatar
thanks for all the replies i got with this problem
I solved it, it was because the window's regulator was broken, and had to replace it , but the Rivets were truly a pain in the A$$ to mount the regulator back on cause i didn't have a tool large enough to put them in.......
Old Oct 7, 2008 | 07:12 PM
Solidjake's Avatar
02 330i & 99 ML430
you're welcome
you should go to benzworld.org to deal with problems with your ml. they are a lot more active
Old Oct 8, 2008 | 02:29 AM
jtse's Avatar
really?
but I have always asked and stayed with mbworld for quite some time......
Old Oct 9, 2008 | 06:32 PM
Solidjake's Avatar
02 330i & 99 ML430
Originally Posted by jtse
really?
just check out benzworld. the w163 is always in motion
