ML320 - How do I get at brake bulb in tail light assembly?
I need to replace the brake light bulb in one of the 1999 ML320's tail light assemblies. I need some assistance in getting at the bulbs in the two tail light assemblies. How do I gain access to the inside back of the lamp assemblies in order to pull the bulb and socket out? I specifically need to access the assembly/bulb in the passenger side of the car. Also, does anyone know what bulb type/number it would be for the brake light bulb (is it a standard P21W)?
Thanks,
Walt
Thanks,
Walt
TIP: A PLASTIC wedge used gently between the body and the lamp housing on the lower forward edge (where the snap lock is located) can help to ease a "stuck" snap lock. A bit of silicone before reassembly will make this easier if you have to do it again.
