Transmission drops into lower gears
Wacky Trans Computer
Okay, so I've read up a bit on how ML's trannys have problems due to oil leaking into the trans computer, and I believe that is what happened to mine.
One weird thing is my transmission will not drop down a gear in manual shift gears 1-3, but the second I shift it into 4th or D, it starts to drop gears and slip into neutral.
If this was a trans computer problem, I would think it should affect all gears.
I've also read that this problem might come due to a trans conductor plate opening, would this only affect gears 4 through D?
I have already tried to reset the computer (gas pedal down, key from 3 to 0, gas pedal up, etc.), does not seem to do anything.
Thanks for any and all responses.
hex
hex
Don't you mean fluid leaking onto the plug connector on the driver side of the transmission pan? That has known to cause problems. Unplugging it and spraying it out with contactor cleaner usually does the trick.
