2003 ML350 BAS/ESP Help
Again, there are no code(s) being generated. On Answer.com a MBZ mechanic indicated ECU module or Brake Booster issue. From the forums here, Ive seen Brake Switch, Brake Pressure Sensor, and ABS control unit.
Has anyone experienced anything similar?
Vehicle has ~123K miles and recently had crankshaft position sensor and had mechanic check brakes at that time (all were OK)?
