2000 ML320 throttle/idle trouble
ML320
I am having trouble with my ML320. When I start the car it idles fine. If I push the gas peddle in about 1 inch it accelerates smooth. If I push the peddle to the floor the car will not accelerate and will jerk like it is down shifting. Then the car will idle rough and hardley make it up to 20mph. If I turn the car off and back on it will be back to idling fine and running the same. I can never push the peddle all the way to the floor. Does anyone have any ideas of what the problem is? The check engine light is on.
Its a 2000 Ml320 - were the plugs changed at 100K miles?
I don't know how many miles you have on it, but I would suggest changing plugs at the very least as a starting point, if you haven't done so..
Next to look at are the ignition coils..
I would check the whole fuel injection circuit. From the MAS Air flow sensor to the oxygen sensors...something in the fuel injection circuit is not right...
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Could also be the plug wires themselves or, perhaps you installed the incorrect plugs or another sensor has failed. Is the misfire code the only code you are getting??
