99ML430 DRIVER DOOR WILL NOT OPEN DOOR
my drivers door will not open from the outside when ML is unlocked. you can pull on the handle like normal and nothing. Lock goes up when unlocked.
tested everying way possible and narrowed it to handle issue.
what is the MBZ part # that I need?
Is this a common issue?
how do I remove the inside door panel with out busting any clips?
