Trunk Light Switch
Old Jul 16, 2009 | 12:04 PM
PAUL R's Avatar
Question Trunk Light Switch
Trunk Light Switch,could someone tell me where it is please.
The exact location, and the colour of the wires that are attached.
As i can not get the light to function automaticaly when the trunk boot is opened.
It works manually on and off, but not automaticaly.
All help greatfully accepted
Old Jul 28, 2009 | 09:06 AM
PAUL R's Avatar
It appears that i'm not the only one that dosen't know then,
40 veiws and no comment,whats happening here guy's
Not even a trawel through the net revels where it is, and a look on an old version of WIS dosen't even show it.
Any ideas anyone
Old Jul 28, 2009 | 10:59 AM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
As I recall there is a switch in the vehicle that will turn the auto function on and off.You do not mention the year and model of the vehicle, need this info to get the location of the switch
Old Jul 28, 2009 | 12:40 PM
PAUL R's Avatar
Thank you for your reply sosh
The year of our ML is 2000 pre facelift we have had it now for 7 yrs.
If you could supply me with the relevent information it would be much appreciated,
The only switch that controls the interior lighting is the one in the over head center consol at the front, and that only opperates the lights in the rear seating area,not the trunk space.
This is why i'm stuck.
Old Jul 28, 2009 | 05:15 PM
sosh's Avatar
I had 2 W163's, a 98 and an 02. I recall that on the 98 there was a 3 position switch on the light itself, one was totally off, another was on all the time and the 3rd was auto. On the 02 there I believe I recall a switch on the overhead front consol that controlled the auto function but I am not certain. As for the location of the door switch I am sorry but I can't help you
Old Jul 29, 2009 | 03:32 AM
PAUL R's Avatar
Sosh,you may not have helped but, at least you have pointed out an error on my be-half,
i needed to state what model i'm running,
Hopfully one of the ML technitions will come along and tell me were it is.
Cheers
Old Aug 1, 2009 | 05:08 PM
mb_rpl's Avatar
'11 GL350, '03 Audi A4 Avant 1.8T
Do you have park assist?
I don't know if park assist is already available for 2000 models but mine is 2002 and the switch is right on the LED light assembly on the ceiling in the trunk that indicates how far you are from the object you're about to hit when backing up. It has 3 positions: on, auto, and off. Don't know if that helped any...
Good luck with that.
Old Aug 2, 2009 | 11:32 AM
PAUL R's Avatar
Cheers for that,
I know about the 3 position switch in the lamp,
But, the switch i'm refering to is the one that controls the automatic position on that lamp,
Thats somewhere in or around the trunk lid or frame
Old Aug 27, 2009 | 11:26 AM
beachbenz63's Avatar
2008 CLK63AMG cab., 2014 G550
Cheers for that,
I've got an 02 ML320 with the same issue, and according to the dealer, the switch that controls the light is within the lock mechanism. They were able to get it working intermitently, but not consistantly. The suggested solution was to replace the lock mech. At over $300 with labor, I decided to live without the light going on by itself, as it works in all other functions.
Old Aug 27, 2009 | 12:54 PM
PAUL R's Avatar
beachbenz63 Thank you
