Will 09 ml350 wheels fit a 03 ml 350?
Old Jul 17, 2009 | 03:37 PM
Driver55er's Avatar
w210 e55
I think the offset from W164 18" and 19" wheel is ET60 and W163 stock 17" wheel's offset is 52. They both are 8 inches wide.
Someone told me I would have a brake caliper interference issue. Is this true or will the 19's bolt right on?
Old Jul 18, 2009 | 10:40 AM
AmiJIm's Avatar
W163 ml 400 cdi ,R170 SLK 200 Kompressor 192HP!
Hi there,
i have bought a set of 19" 275/55 8.5J wheels from a GL 500 for my W164 ML 400 CDI and i had to use some H&R spacers.I used the 60mm model for 30mm on each wheel for better safety form the 50mm/25mm model.The car has become taller and once the tires goes low,i will use some 275/45 to match my 275/55 17" OEM stock wheel height.
You will also have to use lugs from the SUV you buy the wheels from.The original w163 is too short for the offset of the new ML - GL wheels.
Nice update though.
