Wiring
Old Feb 21, 2003 | 12:33 AM
Sincity's Avatar
Wiring
It is actually pretty easy to drill a hole through the firewall from the passenger side. Remove the panel belowe the glovebox and position your drill as high as you can go. Remember the firewall is double layered sheetmetal so you will be drilling through 2 layers of sheetmetal. I do not have a compartment underneath my front passenger seat and installed a mono 150 watt Hi-Fonics amp that I had for a long time.
