leak
Old Feb 23, 2003 | 11:07 AM
mhaskelo's Avatar
2006 ML 350
leak
mercedes dealer seems to cause new problem each time 99 ml goes in. Question......i notice now at slow speeds(when brake) I now hear a "sloshing" on right side from under car...no visible wetness inside....dealer repaired my sunroof track recently....i wouldn't think it was gas tank?? any ideas???? HELP.....TG for this forum
Old Feb 23, 2003 | 12:56 PM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
The last time I had an ML with a sloshing noise, it ended up being water trapped inside the step bars. Taking the end caps off let the water out and fixed the problem. Of course, if you don't have the step bars, I don't know where to lead you.
Old Feb 23, 2003 | 01:16 PM
mhaskelo's Avatar
2006 ML 350
leak
I now see dripping from under rocker pannel.(plug?)....as the truck has been sitting in one spot......it is water
Old Feb 24, 2003 | 09:47 AM
Darkmann's Avatar
ML
Yes, it's water. What's happened is that you drain plug by the rockers are plugged. Unplug the drain plug (you can actually pull the rubber plug out and replace it after draining) and you'll be fine.
Old Feb 24, 2003 | 09:49 AM
Darkmann's Avatar
ML
Yes, it's water. What's happened is that you drain plun by the rockers are plugged. Unplug the drain plug (you can actually pull the rubber plug out and replace it after draining) and you'll be fine.
