crank shaft sensor
Old Oct 1, 2009 | 06:48 PM
alljoni's Avatar
ml 320
crank shaft sensor
Crank shaft sensor blew up ==> replaced it. Car was running for 20 minutes. All the sudden while I was driving, almost all warning lights came on,alarm was beeping and the car started shaking.
Any ideas?
Old Oct 11, 2009 | 05:25 PM
LeviDenim's Avatar
2005 E500 4matic, 99 ML 430, 90 E300
I would have the codes read as soon as possible. There is probably a misfire code. Then
you just have to find out what is causing it.
