lights!!!!
Old Oct 2, 2009 | 07:15 PM
str8upclownen's Avatar
ML350
lights!!!!
can anyone help? i have the left 2 lights on the dashboard on? i believe there the bsp and the one next to it is bsp/ets light anyone know anything on this lights? thanks Steve
Old Oct 3, 2009 | 09:00 AM
benz 4 jts's Avatar
00 ML430, 00 E320 4matic wagon
This is a common problem. Th e most often cause for this is the break light switch. Seach the threads and you will find a DIY for the switch. It is one of the less expensive fixes, about $15 at the dealer.
Good luck,
Benz 4 jts
Old Oct 11, 2009 | 03:54 PM
ML350
thank you, i finally got my internet up and running again the lights are the bas/esp light and the ets lights???? is it still the same fix???? thanks Steve
Old Oct 12, 2009 | 07:26 PM
benz 4 jts's Avatar
I kind of know what you meant and the answer is yes. Now, what I meant by "$15 at the dealer" was for the part. You can change it out yourself.
Benz 4 jts
Old Oct 12, 2009 | 10:25 PM
Mka77's Avatar
06 CLK350 -SOLD! 2010 Cadillac SRX Premium Turbo
That's good to know. I have seen the same light pop up on the 00' ML430 I just purchased. Mike
