ML350 Problem
Old Oct 11, 2009 | 02:26 PM
korruptusi's Avatar
ML350
ML350 Problem
Hi all well I recently did the Service A on my car its a 2006 ML350 it has about 29000 miles on it and about 2 weeks or so Ive noticed that if I go above 70mph the car starts to shake like crazy anyway I wanted to see what would happen if I went above 100mph and it didnt shake as much. Anyway I had a flat tire a while back but they didnt fix it correctly so now it becomes flat every now and than I thought that might be the problem but am not sure. Could it be the engine or the tires? Has this happened to anyone? Any suggestions are welcomed.
Btw everything was green as in no problems with the car according to MB when i did the service.
Old Oct 11, 2009 | 03:29 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
First I would have a look at the possible basic causes of the problem. Easiest to check is the wheel balance. This is also the most probable cause. could be with the flat repair a wheel weight was knocked off. Its also possible that that tire was damaged and has a bad belt. If you must go deeper to correct the issue get back on this site as there are other possible causes but its unlikely.
Old Oct 11, 2009 | 09:50 PM
LeviDenim's Avatar
2005 E500 4matic, 99 ML 430, 90 E300
I don't like the sound of the tire issue either. That is the best place to start.
That small leak has to be fixed. Then balance that tire again. Post back
with the results.
Depending on the tire damage it may never be perfect and there is an
outside chance the tire may need replacement.
Old Oct 13, 2009 | 10:34 AM
korruptusi's Avatar
ML350
Hey guys thank you for the quick replies well good news I went and checked the car and turns out that tire was damaged so I had the four of them replaced since i havent replaced them in a while and the problem has been fixed finally
Thanks again for all the help Claud.
