Drivers window won't do up need some heilp
Old Dec 28, 2009 | 02:11 PM
Nicness's Avatar
ML 430
Wouln't you now it the worst storm in 20 years in MN and I go to BK and put
the window down to order and have to drive home with window down. Ok I
had it half way down and it wouldn't do up. It still went down I believe it
is a switch problem. Is there a way to get it up? If so how do you get the
switches out of the console. Asking so I don't break anything. If it is a switch where is a good place to order a new one. If it's not the switch how
do get the door panel off to check the motor. Thanks
Nic
Old Dec 30, 2009 | 08:20 PM
Nicness's Avatar
ML 430
Well I found the problem the switch. I also found this very helpful
how to. Takes about 15 min's just follow the instructions.
I can't believe no one offered any assistance.
http://www.nicedeals.co.uk/blog/diy-...h-replacement/
Old Jan 6, 2010 | 09:30 PM
Boston Mark's Avatar
1998 ML 320 1975 450 SL
I just saw your posting so this info is just a little to late.
When I had this problem I took the switch out, gave it a good shot of WD-40, put it back in and it worked for a couple of days till my replacement switch came in. Worked for me..... Twice!
Boston Mark
