BAS ESP,ETS & ABS Yellow Warning Lamp on
Old Jan 4, 2010 | 09:11 PM
GarzML500's Avatar
ML500
Question BAS ESP,ETS & ABS Yellow Warning Lamp on
This is my first post, I hope someone can help me with this problem.
I was driving MY 2003 ml500 and all of the above items poped up in yellow is this a serious problem related to the power assist on the brakes or is it related to the alternator possibly not charging above 10 volts.
GarzML500
Old Feb 3, 2010 | 02:30 AM
Jacobmwambene's Avatar
ML 320
I have my ML 320 with BAS/ESP and ETS&ABS lamps on. it starterd about a month ago and when i went to the workshop i was told it is because the brake pads are warn out. After replacing the pads the ETS&ABS went off for one day and letter it went on again but the BAS/ESP did not went off at all. what could be the problem can you help me as the lights irritate me when driving.
Old Feb 3, 2010 | 01:39 PM
aznxtacy's Avatar
ML500
For BAP/ESP, it's probably your Brake Light Switch, do a search and you'll find out how to change it. It's very simple and a $20 part. Also, it would help if you have a code reader if the check engine light is one to find out what's wrong.
