2001 ML320 Rear Washer Pump
My rear washer pump doesn't seem to be working. I replaced the pump with a new one and also replaced the fuse (it was blown) and there still doesn't seem to be any power going to the pump. I am not sure where else to look and was hoping someone else has had this problem and could help out. The front works great so it's not like there is no power going to the pumps.
Thanks for your help!
It just maybe that the switch its self has died.Is the fuse still good? If you have to change out the switch you will need to pull the panel. The one on my 1998 ML is held in with clips and glue. You will need to gently pry it out to get to the switch.
Boston Mark
On the other hand... I didn't think the plugs and wires could cause the idle symptoms I was experiencing, but after replacing them, they fixed the problem. So maybe it is the switch! Thanks for responding!
Boston Mark
! Also..my check engine light keeps coming on. It will go off sometimes but then comes back on. Not really sure what the problem is. Any ideas? ThanksOh..its a 99 ML320 with 164,000...
Thanks in advance!
