Idler and Tensioner Change
Little did I know that my idler was cracking and my tensioner was no longer spinning smoothly.
Here's a pic of my idler next to the new one. Scary!
All in all fairly simple job.
The scariest part is holding the tensioner tensioned with a pin so that you can gain access to the bottom torx bolt. Scary since there's quite a bit of tension locked up there.
Don't forget to check your tensioner too.
Might be in bad shape given the condition of the idler.
