Window help plz...
Old Apr 19, 2010 | 09:17 PM
s.f.clk02's Avatar
CLK320 2002
Window help plz...
Hey wusup everybody..
Last night i was driving home and i heard a huge pop on my passenger side... later the next day when i rolled down my window it worked fine but when i went to put it back up it would not rise... the motor and everything seems to be working fine I'm guessing it popped out of its like socket.. I took off the side panel on the passenger side but im not sure how the motor and stuff works so please help me out im really not trying to take it to the dealership...
its a 2004 ml350 ive searched for the issue on here aswell but couldn't really find much
Old Apr 26, 2010 | 06:28 PM
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
could be the switch on the center console. My window stopped working couple weeks back There was no power or click at all to the motor and at the end I decide to take the switch apart.
I bend the contact point slightly and put it back to gether. It worked after that. It is tricky to get all the switch back together perfectly. in fact my rear defroster switch dont work now. I suggest gettting a new switch cluster from ebay.
Old Apr 27, 2010 | 06:41 PM
eclass's Avatar
1999 E320, 2000 ml430
take the other door panels off and see how it works..
Old May 2, 2010 | 03:05 PM
cfwp81a's Avatar
2000 ML55 AMG 2009 E63 AMG 1999 Ford Mustang GT Vortech 1970 Dodge Dart 340
Because you heard a pop the day before, I would check the window regulator. There is a plastic clip that can break. This will cause the window to stay down even though the motor is still working. It is similar to a 94 Toyota Camry, which is notorious for this same incident. You can purchase a complete window regulator assembly from EBay. I have seen them for sale on there for years. Incidentally, the regulators are often position specific. So they are usually sold as RR, RF, LF, or LR respectively and are not interchangeable. Good luck!
