Horn Not Working??
If anyone can help out with some suggestions, I would greatly appreciate it. Many thanks in advance!
See if you've got power going to the horn leads. If you do, then horn is bad. If you don't, you may have a short between the relay (I presume it's a relay'd system since you're hearing a click) and the horn leads that connect to the horn.
