Look at it this way
I will use aftermarket stuff for other things, specifically shocks, bulbs, and stuff made by bosch that you can get outside the dealer. Other than that, anything other than original on an MB, besides rims, tires and that stuff is unacceptable.
What are you going to reccomend next? that we dont use original mb tranny fluid and anitfreeze?
As someone in the auto repair business, you should research what is available so you can make recommendations for specific applications. Mercedes doesn't manufacture brake pads. They buy them from Jurid, Pagid, Textar, or some other manufacturer. Why would you assume that the OEM pads are the best pads available?
Have you ever heard of Hawk? Brembo? EBC? Rotex? Mintex? Performance Friction? Axxis? Etc,.........
Each of these companies has a pad that would be far better than any stock pad Mercedes uses.
They use the same pads as cars that are 1000lbs lighter? What does that mean?
"original mb tranny fluid and antifreeze"
Do you think Mercedes manufactures oils & coolants?
