ML270 inlet manifold leaking help needed
Could someone tell me the cause for this and also is there a cure other than changing the manifold itself.
Thanks Mal.
1-First i have done
2-i have removed all swirl flaps from the manifold (dont disconnect servo cable) and block the holls with bolt and nut with rubber washers
Now everthing okey no oil no turbo boot escape.
