2005 ML500 keeps killing batteries
My wife has a 2005 ML500 that consumed the original battery. I thought nothing of it as it was 4 years old and has 35,000 miles.
I installed a new battery and checked the voltage after installation and it was charging fine.
The crank position sensor went out next and this too I changed.
Now after calling my wife. [I am currently in Afghanistan] she tells me that the new battery is completety dead in the garage.
My question is: Is there a history of hot circuits or faulty electronics that kill batteries after only 2 months of service and having not been started fo 10 days?
My OBS II scanner showed no faults before when I was trouble shooting the CPS.
Will the dealer's scanner show what is doing this?
Any assistance will be greatly appreciated so that I can tackle this new problem upon my return home.
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Could it be that your wife left something turned on?? Its also possible that you got a bad battery and possible also that there is some sort of draw from some accessory that would cause this. Fairly easy to check with a meter but difficult to pinpoint if it does draw.
she assures me that nothing was left running, and I am pretty sure the battery was a good one when I installed it.
I am just trying to see if there has been another scenario like this one that has plagued someone else.
Thanks for your thoughts.
I cant recall seeing any complaints about the car running the battery down on the W163's. I have on some other models. The first thing I would do is to confirm that the battery is good. Brand new batteries have been known to fail.
Open hatch or door...
That kept the door lock circuit/hatch light open & killed the battery over 3 days.
Just some pointers...
